Profinet as a software solution
Bill84
Is it possible to add Profinet to my device using a software solution ?​
Bill84 wrote: 04 Oct 2023, 11:27 Is it possible to add Profinet to my device using a software solution ?​
Yes, it is possible. There are some vendors available offering such software-only solutions.
Depending on hardware capabilities, you may have some limitations such as
  • not reaching the highest specified netload class
  • not reaching fastest specified network update time
  • not being able to have a synchronized communication (IRT or TSN Streams)
But for most devices, that will not be a sevear issue.
ip01
Re: Profinet as a software solution
Is the pi profinet-community-stack a suitable start point for creating a client software implementation on Windows PC?
ip01 wrote: 06 Oct 2023, 13:19 Is the pi profinet-community-stack a suitable start point for creating a client software implementation on Windows PC?
I advise you not to go that way unless you are very experienced with Profinet. The Community Stack is only a pure Protocol stack without dedicated APIs for the application and only an example adaption to Ethernet.
I recommend using a dedicated SDK from a technology provider, which can off course base on the Community Stack.
Thanatos
Hey Bill! ok you just blew my mind... Can you back this truck up for us newbies? :D
What type of device are you thinking?
and somehow you are going to implement Profinet onto it? :shock:
Hmutlu
please check the below solution;
https://mall.industry.siemens.com/mall/ ... s/10228079
FloLi
Re:
benja_m wrote: 09 Oct 2023, 09:11
Can you point out some Profinet SDK providers?
Is it possible to get the community stack for evaluation before deciding on a membership?
Re: Re:
FloLi wrote: 08 Jan 2024, 12:17
Did you have a look here: https://www.profinet.com/profinet-expla ... ementation
There is a page linked showing technology providers. This can give you a hint.
