IM5_Supported_ETS_ART_2.44.1_Problem
Hello PROFINET Forum experts.
I have a couple of problems. For the other I will start another post.
This is strange. With ART 2.44.1 we are testing our solution which now supports I&M5 (the previous version didn't so this is the first time I see this.).
The ART is telling me that the GSDML file does not enable IM5_Supported="true". However this is not correct. Our GSDML file has the IM5_Supported="true" entry.
However, the different access ways test case fails with the error:
"According to the GSDML the 'IM5_Supported' is not set to 'true', but
the device states in its corresponding supported IM Bits, that it is supported.
This inconsistency is allowed."
:cry:
benja_m
Re: IM5_Supported_ETS_ART_2.44.1_Problem
AlfredoAtSherpa wrote: 17 Apr 2024, 09:42 Hello PROFINET Forum experts.
:cry:
Parts of this was fixed in the meantime. Please check with last available Innovation bundle.
https://www.profibus.com/download/profi ... tsn-and-pa
benja_m wrote: 17 Apr 2024, 16:45 Parts of this was fixed in the meantime. Please check with last available Innovation bundle.
Thanks so much. With this newer 2.44.3 version we do not see this problem.
Alfredo
rottava
I'm having this exactly same problem when testing my device, but with the latest ART, version 2.45.0.2.
Could it be a regression in test bundle? Does anybody experienced similar issue?
Thanks.
benja_m
rottava wrote: 26 Feb 2025, 14:23 Hello,
Thanks.
Yes, i see the same issue (message "According to the GSDML the 'IM5_Supported' is not set to 'true', but the device states in its corresponding supported IM Bits, that it is supported. This inconsistency is allowed") here. But it does not lead to "fail" in our case. Test is "passed with hint".
rottava
benja_m wrote: 26 Feb 2025, 15:29
Thanks.
Yes, same here with ours, "passed with hint". Needed to be sure though.
Thank you!
