Netload Normal Test Log File
No longer a member
When I did Netload Normal test item 1 (Crap-Multicast frames 64 byte) test, can't generate the log file folder in the directory "/root/Netload/out/", file folder path see attached.
I am not sure whether this is some configuration issue or computer permissions reason.
Please help to give some suggestion.
AIT-Support
Re: Netload Normal Test Log File
No longer a member wrote: 03 Jun 2024, 08:42 When I did Netload Normal test item 1 (Crap-Multicast frames 64 byte) test, can't generate the log file folder in the directory "/root/Netload/out/", file folder path see attached.
This problem occurs mainly for the following two reasons.
1. The wrong Ubuntu version is being used. Version V18.4.3 LTS must be used without any further updates.
2. "blank" shall not be used in the testling_Id.txt.
Example: "Device Type" is not allowed, "Device_Type" is allowed.
