Automated RT Tester: How do you determine which test cases you need to run on a specific DUT?
After setting up a new project within Automated RT Tester, how is determined, which testcases you have to execute on a specific DUT?
Re: Automated RT Tester: How do you determine which test cases you need to run on a specific DUT?
Just select all test cases and run them. If a feature is optional and not implemented, the corresponding test cases will be skipped automatically. The decisions are based on the GSDML or CDML provided to Automated RT Tester during project creation.Webinar_Question wrote: ↑24 Nov 2025, 09:21 After setting up a new project within Automated RT Tester, how is determined, which testcases you have to execute on a specific DUT?
dennis_binder
how about the "Manual Testcases", "Netload Robustness", "Additional Testcase".Raik.Zachmann wrote: ↑25 Nov 2025, 08:27Just select all test cases and run them. If a feature is optional and not implemented, the corresponding test cases will be skipped automatically. The decisions are based on the GSDML or CDML provided to Automated RT Tester during project creation.Webinar_Question wrote: ↑24 Nov 2025, 09:21 After setting up a new project within Automated RT Tester, how is determined, which testcases you have to execute on a specific DUT?
Do I also have to activate them and the RT Tester will do what it needs to regarding the given gdsml file ?
Or can I deactivate some of them, "Manual Testcases" seems not very reasonable to me.
Best regards,
Dennis
