Is it necessary to get a Profinet certification if we use a hardware chip designed on our controller board?
Is it necessary to get a Profinet certification if we use a hardware Chip like the one from Hilscher designed on our Controller Board?
Re: Is it necessary to get a Profinet certification if we use a hardware chip designed on our controller board?
Yes, it is! The solution is "only" pre-certified confirmed by a so called Technology certificate. The final product using this solution must be tested and a needs an own certificate.Webinar_Question wrote: ↑24 Nov 2025, 09:48 Is it necessary to get a Profinet certification if we use a hardware Chip like the one from Hilscher designed on our Controller Board?
