Is it possible to set/change the cycle rate of the ETS tester for in House tests?
Re: Is it possible to set/change the cycle rate of the ETS tester for in House tests?
Currently it is not possible to adjust the cycle rate. Some Testcases modify the cycle rate and/or iterate through the possible cycle rates. It would be quite problematic in certification to guarantee the usage of all needed/possible cycle rates with a setting like this.Webinar_Question wrote: ↑24 Nov 2025, 09:42 Is it possible to set/change the cycle rate of the ETS tester for in House tests?
