Test result “PassWithHint”: what does that mean?
Using the Automated Runtime Tester sometimes the test result PassWithHint is reported? Could you explain this result a bit more.
Re: Test result “PassWithHint”: what does that mean?
A PassWithHint is generated, in case a value is allowed, but not the recommended value defined in the PROFINET specification. The resulting hint is put in the test report issued by the PI Testlab.Webinar_Question wrote: ↑24 Nov 2025, 09:24 Using the Automated Runtime Tester sometimes the test result PassWithHint is reported? Could you explain this result a bit more.
