Will old ETS (TMDX654IDKEVM) be able to support controller test for v2.5 as well as v2.4 tests
Hello. The question is as per subject.
Thanks for the confirmation.
I understand that, of course, TMDX654IDKEVM cannot support 1G or 10G, and cannot support IRT test nor netload test.
Re: Will old ETS (TMDX654IDKEVM) be able to support controller test for v2.5 as well as v2.4 tests
AlfredoAtSherpa wrote: 10 Jun 2026, 07:17 Hello. The question is as per subject.
PITL's must use the new IPC instead if the TI IDK, but the Test Bundle V2.50 will contain FW-Images for both, IDK and IPC. Giving the customer the possibility to use the IDK. As you already said, the IDK is not capable to run all provided test cases.
Raik.Zachmann wrote: 15 Jun 2026, 13:35 Hello,
Raik, thanks so much for this confirmation. So PI Test Labs must use the new industrial PC version of the embedded test system, however PI will provide images for both, the IPC version and the TI IDK version. This is so very helpful.
