Can you use multiple connectors on one SPE line? Or will those connectors disrupt the signal?
VoGo
Contact:
Re: Can you use multiple connectors on one SPE line? Or will those connectors disrupt the signal?
Webinar_Question wrote: 20 Jul 2026, 09:26 Can you use multiple connectors on one SPE line? Or will those connectors disrupt the signal?
APL and SPE in general are still switched ethernet networks and point-to-point connections - one connector at each end of the wire only.
The 10BASET1S standard, that we did not cover here, allows multi-drop operation. But it is limited in length and node count that can be attached to a single cable.
