New ETS firmware not provided in Test Bundle downloads
Hi. I cannot find the new firmware for the ETS board in the test bundles provided on the PI site.
I cannot execute the ART, as a result.
Is it possible that the test bundles were updated without the ETS firmware?
j.rost
Re: New ETS firmware not provided in Test Bundle downloads
AlfredoAtSherpa wrote: 16 Dec 2023, 10:04 Hi. I cannot find the new firmware for the ETS board in the test bundles provided on the PI site.
Install the Automated RT Tester and within the installation directory of the Automated RT-Tester (default: "C:\Program Files (x86)\Automated RT-Tester") you find the EtsFirmware folder which contains the fitting EtsFirmware for this version. It was always there and the duplication in the bundle itself was removed. This is also part of the corresponding documentation.
BR
Julian
j.rost wrote: 18 Dec 2023, 08:55 Install the Automated RT Tester and within the installation directory of the Automated RT-Tester (default: "C:\Program Files (x86)\Automated RT-Tester") you find the EtsFirmware folder which contains the fitting EtsFirmware for this version. It was always there and the duplication in the bundle itself was removed. This is also part of the corresponding documentation.
BR
Julian
Thanks so much. Will look into this in the next few days. I realize the ETS manual "clearly" says so. Sorry about that.
