Having Windows User interface capable in reading TCP/IP, UDP, serial etc messages but now customer say "having data string using profinet protocol". Do you need some Profinet interface card installed in PC for this? And/or some dll to read data string as TCP/IP?
How to read profinet data string
llindemann
Re: How to read profinet data string
I find it difficult to understand your concern here. As far as I understood, your are developing an customer application (running on Windows) gatehering information from devices. As a next step PROIFNET communication shall be added. Your basic question targets what is required to incorperate the PROFINET to your application.alan wrote: ↑27 Sep 2024, 17:53 Hello,
If I got this right, the following applies:
- You do not need specific hardware interfaces in your Windows PC ( at least not for tool access).
- Tools typically utilize the record channel and thus the tech stack IP, UDP, CLRPC, PNService/ Records. But this may vary depending on what is meant by "having data string using profinet protocol".
Anyhow, could you provide some details on "data string using profinet protocol", thx.
