Controller tests and necessary exchange of information between ART Tester and DUT
If the controller tests with the ETS no longer require TFPC, what is used instead to exchange the necessary information between ART Tester and DUT? What changes are required for already implemented controller tests that are based on TFPC as stated?
s.zach
Re: Controller tests and necessary exchange of information between ART Tester and DUT
Webinar_Question wrote: 09 Sep 2024, 09:43 If the controller tests with the ETS no longer require TFPC, what is used instead to exchange the necessary information between ART Tester and DUT? What changes are required for already implemented controller tests that are based on TFPC as stated?
There is no substitution of TFPC. With splitting the testcase into scenarios, there is no need to exchange testcase related information.
For every testcase with implementation on the controller has a special testcase engineering TCIS that explains what the implementation has to provide.
