Does ETS-Board is necessary for PN pretesting?
sagar.dukare
Hello Team,
I want to test my Profinet device before sending it to the certification lab and for that I found the PN test bundle on PI website. The PN specification doc says that, to do the PN pretest we need to use the ETS-Board. Does it necessary to use the ETS-Board or we can use any Profinet IO controller to test the same.
Thank you in advance for your reply..
Best Regards,
Sagar
Re: Does ETS-Board is necessary for PN pretesting?
sagar.dukare wrote: 16 Oct 2024, 07:37 Hello Team,
Best Regards,
Sagar
If you want to execute the certification tests with the automated tester software, you have to use the ETS board.
sagar.dukare wrote: 16 Oct 2024, 07:37 I found the PN test bundle on PI website.
In the test bundle look for test specification Testspec-PN_2572_V245_Jun24.pdf.
Chapter 5.5.5 table 5-22 lists the tests and required test setup.
Except for InterOp tests, all tests are run using the ETS test setup.
