I have continued working on the tests and now one of the last sticking points is the TEDCheck (CLRPC)(Cisco) test.
It's failing with the following error message (for both Standard and Legacy test):
"No IPv4 address for remote entry 0.2.2 found in lldpRemManAddrTable"
I am trying to figure out what's wrong, so any hint will be very appreciated.
Attached one can find two Wireshark logs generated by the ART.
Not sure if it matters but, first two tests, CLRPC and CLRPC Aruba, are passed, this one (third) is failing, and the fourth, (Cisco + Aruba) is skipped.
TEDCheck (CLRPC)(Cisco) test failed
- Attachments
- TEDCheck_CLRPC_Cisco.zip
- (133.38 KiB) Downloaded 1652 times
Re: TEDCheck (CLRPC)(Cisco) test failed
Hello,rottava wrote: ↑03 Feb 2025, 17:16 Hi,
For the record, contacted the supplier of the PROFINET hardware and was informed there was a firmware update that fixed several issues, including some related to LLDP. With this new firmware, TEDCheck tests are cleared.
So for those that spent time looking at my messages trying to figure out what was wrong, thank you very much.
