PROFIsafe test returning a connection error
rottava
Whenever I try to run the PROFIsafe test (under Additional Testcase -> Profiles), I get an error message saying:
09:12:21 - Starting Testcase: PROFISAFE V2.4 STARTUP
09:12:23 - Configuration Test step 2: No PROFIsafe capable submodule with the selected version PROFIsafe V2.4 is available in the current configuration.The test case is skipped.
09:12:23 - ERROR: EtsConnectionState is Undefined. Check configuration / connection.
09:12:23 - ERROR: The connection to the ETS was lost. Further test execution is aborted.
09:12:24 - Test execution finished.
My device does not support any profile, not even PROFIenergy. However, PROFIenergy test is skipped.
So my question is; is it normal these ERROR messages above? Since it's not support, I was expecting another skip.
Thank you.
Re: PROFIsafe test returning a connection error
rottava wrote: 06 Feb 2025, 13:27 Hello,
Thank you.
In your case the messages are only in the log, correct? In the report the tests are reported as skipped.
I also see those ETS connection messages from time to time, and I usually ignore them...
rottava
olliew wrote: 06 Feb 2025, 17:00 In your case the messages are only in the log, correct? In the report the tests are reported as skipped.
In the Certification Report those tests appear as "None", in red. PROFIenergy indeed appears as "Skip".
And in left-hand side, the test panel, those PROFIsafe V2.4 and V2.6 don't have the black dot indicating test was skipped. I am ignoring these messages for now as well. But since I am about to start the official certification process, didn't want to submit logs with errors, even false positives.
rottava
rottava wrote: 06 Feb 2025, 17:28
Guys, don't bother. Switched off everything, waited 5 min and powered up again. Run those tests only and they were skipped.
That's good enough for me.
