P2P-Setup Tests for Certification mandatory?
Booster
Hello everyone,
in which cases are the tests with P2P-Setup mandatory? Are these testcases required for certification with 2 or more port devices? (Especially "Different Access Ways P2P" because in list of test specification these test is not listed (Pn-Spec 2021))
Thanks for your answers!
DanielS
Re: P2P-Setup Tests for Certification mandatory?
Booster wrote: 12 May 2025, 12:06 Hello everyone,
the P2P tests are always mandatory. It doesn´t matter how many ports the device has. By the way the Pn-Spec from 2021 is long outdated. With the actual test system (with ETS-Board) Version V2.45.0.2 the testsystems recognizes which test can be skipped and which need to be performed. As there are all partner devices will be simulated you also do not need a specific P2P Test setup.
