PROFIdrive conformance tool V6
Posted: 30 Jul 2025, 09:48
by Jahi
I have Profile tester version 6.0.0.0 Inc. 38
I have defined this variable "$fault_1_possible" to be 0 (same value as with older tool version)
# variables for Fault buffer tests
#version of the fault buffer: 0 = minimum fault buffer, 1 = complete fault buffer
$complete_fault_buffer = 0
#select, if Fault 1 /Fault 2 /Warning can be simulated
$fault_1_possible = 0
$fault_2_possible = 0
$warning_possible = 0
When I execute this test "DA_Diagnosis_Reset_timing.rb" I get this error “Result: Error, state: 6, Error: undefined method `close_ar' for nil:NilClass”
22:54:04:178 dut - 1.1 (DO-ID 1) Information No error message can be created, no fault buffer test possible.
22:54:04:180 Script errored Result: Error, state: 6, Error: undefined method `close_ar' for nil:NilClass
I assume it is this test that it executes (from "DA_Diagnosis_Reset_timing.rb") when it fails
if $fault_1_possible == 0
$str = sprintf('No error message can be created, no fault buffer test possible.')
message($str)
$connection1.close_ar()
abort_test()
end
What does that error mean and where could the issue be? In my config file or in the test itself?
Re: PROFIdrive conformance tool V6
Posted: 31 Jul 2025, 14:59
by Raik.Zachmann
Jahi wrote: ↑30 Jul 2025, 09:48
message($str)
abort_test()
end
Hi,
which kind of device you are using, Encoder or Drive? (I guess an Encoder). You must define a way to generate faults to verify the the mandatory diagnosis behavior. Did you create a new global file? I would expect that Acyclic_Functions_DA.rb or Acyclic_Functions_DA_ENC.rb were not executed before running the mentioned test script. Those functions are automatically executed out of the latest global file. Please get in contact with
[email protected], which is the official support for Profile Tester and Script issues.
Posted: 31 Jul 2025, 15:13
by Raik.Zachmann
Raik.Zachmann wrote: ↑31 Jul 2025, 14:59
message($str)
abort_test()
end
Hi,
It could be also related to line "$connection1.close_ar()" as the device access AR is established later in the script. This line should be removed like in DA_Diagnosis_Edge_monitoring.rb.
Posted: 01 Aug 2025, 14:13
by PD_Benny
message($str)
abort_test()
end
the exception is thrown because of class variable $connection1 has not been instantiated. In a future PT release the check if DUT supports a failure will be after opening the DA AR.
