With SecurityClass 1, digitally signed GSDs (GSDX) are mandatory.Will those be tested as a part of PN conformance tests?
With Security Class 1, digitally signed GSDs (GSDX) are mandatory. Will those be tested as a part of PROFINET conformance tests?
Re: With SecurityClass 1, digitally signed GSDs (GSDX) are mandatory.Will those be tested as a part of PN conformance te
Yes, the GSDX file shall be delivered to the PI testlab for evaluation latest after finishing all other tests. The lab will verify that the GSDX file contains the same GSD file that was used for the certification tests. So far, the different tester applications using the GSDML file only, because they are not capable of loading GSDX files directly.Webinar_Question wrote: ↑24 Nov 2025, 09:37 With Security Class 1, digitally signed GSDs (GSDX) are mandatory. Will those be tested as a part of PROFINET conformance tests?
