CU310-2 PN configuration for PROFINET interoperability test case (TIA Portal / Startdrive)
FredB
I am currently testing our PROFINET IO Controller using the interoperability test cases from the certification process.
In the list of devices we must support, there is a SINAMICS CU310-2 PN.
I have this device available, but I am struggling to configure it correctly for use with a non-Siemens controller.
I understand that configuration must be done using TIA Portal with Startdrive. However, I am unable to achieve a configuration that matches the device description provided by the certification team.
The expected structure is described as follows:
Slot 1: DO_SERVO
Subslot 1: Module Access Point
Subslot 2: PROFIsafe Telegram 30 (Addr 50)
Subslot 3: Standard Telegram 3, PZD-5/9 (SERVO)
Slot 2: DO Control Unit
Subslot 2: Without PROFIsafe
Subslot 3: Siemens Telegram 390, PZD-2/2
From what I understand, this corresponds to a multi-DO configuration, but I cannot reproduce this setup in TIA Portal with a CU310-2 PN.
In particular:
- I do not see how to configure multiple Drive Objects (DO_SERVO + DO Control Unit)
- PROFIsafe seems required in the description, but I am not sure if it is mandatory for certification tests
- The Telegram combination (Telegram 3 + Telegram 390) is unclear for this type of hardware
To clarify my request:
- I am specifically looking for guidance on how to configure the CU310-2 PN in TIA Portal / Startdrive
- I am NOT asking about my controller configuration
Is there any official documentation, application note, or example project that describes:
- The expected PROFINET module layout for CU310 in certification context
- How to configure Drive Objects and telegrams accordingly in TIA Portal
- Whether PROFIsafe is required or optional in this scenario
Any guidance or example would be greatly appreciated.
Thank you in advance for your support.
Kind regards
Re: CU310-2 PN configuration for PROFINET interoperability test case (TIA Portal / Startdrive)
FredB wrote: 22 May 2026, 16:28 Hello,
Slot 1: DO_SERVO
In particular:
Kind regards
There shouldn’t be any issue to configure the CU310-2PN (using the provided GSDML) with the described structure within TIA-Portal.
Attached you can find a screenshot.
To configure the PROFIsafe telegram is not mandatory for the testing.
The main test aspect for using the CU310-2PN within the Interop Test Setup is to check whether the controller/engineering can work with multi-API devices (in this case PROFIdrive API).
So, how to setup/commission this device is not part of the PROFINET Test Bundle.
I would suggest using the tool Starter, as the integration in TIA-Portal is not needed for your use case.
https://support.industry.siemens.com/cs ... 0&lc=en-WW
