Profidrive implementation
mateus845
Is the source code for the Profidrive profile available ?​
Johnathan
Is the implementation of the Profidrive profile mandatory for the servo or stepper drive ?​
ProfiMat
mateus845 wrote: 04 Oct 2023, 10:26 Is the source code for the Profidrive profile available ?​
You should ask your Profinet SDK Technology Provider for providing a PROFIdrive sample code. In case of using Profinet ERTEC Chip/PN Driver an example code be downloaded here: https://support.industry.siemens.com/cs ... /109811947
Realtime
Johnathan wrote: 05 Oct 2023, 09:25 Is the implementation of the Profidrive profile mandatory for the servo or stepper drive ?​
The implementation of PROFIdrive for a PROFINET drive is optional. It's in the decision of the device manufacturer if he offers an interoperable PROFIdrive interface for his drive device or not. Of cause without the implementation of PROFIdrive it's not possible to connect to standard motion controllers using PROFIdrive as interoperable drive interface. :( E.g. PROFIdrive support is necessary to use Motion TOs on a SIMATIC controller. :D
Realtime
ProfiMat wrote: 12 Oct 2023, 15:39
There is also the PROFIdrive Community Project available https://kb.hilscher.com/display/PROFIDR ... ty+Project ;) Here you will find some example implementations with source code for a PROFIdrive device, PROFIdrive controller and Encoder device. The community project shows adaptions of the PROFIdrive source code to different PROFINET stacks. Also helpfull may be the PROFIdrive implementation guide offering information for the planning and architecture of a PROFIdrive implementation. :D
