Source code example
Mich_P
Source code example
Is there any source code example available for the implementation of PROFIenergy on a Profinet device?
Realtime
Mich_P wrote: 18 Jan 2024, 14:55 Is there any source code example available for the implementation of PROFIenergy on a Profinet device?
I don't now any source code or source code example for a Profienergy device. But at least the Profienergy Service Access Point (PE SAP) uses the same request/respond protocol as the Profidrive parameter access service (BMP protocol). Therefore source code from the PROFIdrive community project may help here (see https://www.profibus.com/technology/pro ... ty-project). While in the Profidrive parameter channel a switch for the request_ids is used, here for Profienergy the dispatching to the different service_request_ids has to be implemented.
There is no PROFIenergy community example.
The stack providers may have an example implementation, if you already use a device stack you can ask your provider.
