F-Parametrization: Relationship PROFIsafe and PROFIdrive
Posted: 18 Oct 2023, 15:19
Question from the PROFIsafe Designer Workshop in October 2023:
Is there a similar feature for F-parameterization via PROFIdrive, which have their own way of parameterization, as for non-PROFIdrive devices, which will then use iPar? It this PROFIdrive on PROFIsafe?
For parametrization of PROFIdrive devices normally the acyclic data channel in a PROFIdrive device is used for e.g. parameterization by using the so called Parameter Access Point of a PROFIdrive device. I just wonder if there exist a similar mechanism for transferring F-parameters to a PROFIdrive device for F-parameters as it will do for non-PROFIdrive devices, which can do the job by transferring the F-parameters via iPar. There exist something called PROFIsafe on PROFIdrive (or vise versa). Is F-parameters covered by this addendum for PROFIdrive?
