Is it possible to have a compact and a modular head unit in the same rack?
Re: Is it possible to have a compact and a modular head unit in the same rack?
Webinar_Question wrote: 22 Mar 2024, 13:45 Is it possible to have a compact and a modular head unit in the same rack?
The device is either defined as a compact device, in which case the user has no option to insert (or remove) modules.
However, you can also design a modular device in such a way that certain slots are already filled, which the customer can then change, or that these are permanently configured. In any case, it is a modular field device. The devkit will allow all possibilities. Ultimately, the GSDML is decisive here.
