Software
Mich_P
Software
What software do I need to set up an SRCI system and from where do I get it?
MarkusL
Re: Software
Mich_P wrote: 17 Jun 2024, 08:35 What software do I need to set up an SRCI system and from where do I get it?
Thank you for your question! SRCI requires two components:
  • SRCI client running on the PLC side
  • SRCI server (also called interpreter) running on the robot controller side
You can get each software component from the corresponding manufacturer. That means, you get the SRCI client from the PLC manufacturer and the SRCI server from the robot manufacturer.
To find out which manufacturers are already supporting SRCI, please refer to the SRCI Vendor Map: https://www.profibus.com/technologies/r ... vendor-map
