Will a I-Device get a separate certificate, or will it be integrated in the controller certificate?
We have a controller, which also supports the device functionality as an I-Device. Will the I-Device get a separate certificate, or will it be integrated in the controller certificate?
Re: Will a I-Device get a separate certificate, or will it be integrated in the controller certificate?
The I-Device will be tested separately, like a “normal” device and will get a PROFINET Device Certificate after passing the tests at a PI test laboratory successfully.Webinar_Question wrote: ↑23 Jul 2024, 11:28 We have a controller, which also supports the device functionality as an I-Device. Will the I-Device get a separate certificate, or will it be integrated in the controller certificate?
